Activity › Forums › Adobe Media Encoder › Adobe Media Encoder GOP settings Broadcast (Finland)
  • Adobe Media Encoder GOP settings Broadcast (Finland)
    Posted by Mari Nieminen on December 13, 2012 at 8:03 am
    I need to get 12 frame closed GOP with structure: IBBBPBBBPBBB. What Adobe Media Encoder settings do I need?
    Atm I have figured I need:
    M Frames = 4
    N Frames = 12
    Closed GOP every 12
    no checkbox on automatic GOP placement.
    Is this correct?
    Also need to cut RGB to 16-235 which I did by applying levels effect to adjustment layer and set outputs accordingly. Is this the correct way to do it?
    I only have the basic CS 5.5 tools in use.
    Mari Nieminen replied 13 years, 9 months ago 1 Member · 1 Reply
  • Mari Nieminen
    December 13, 2012 at 9:55 am
    never mind, figured it out, M frames = 3.
