Activity Forums Adobe Premiere Pro Adobe Media Encoder gone missing ??
  • Adobe Media Encoder gone missing ??
    Posted by Nicky Van der walt on January 30, 2007 at 2:27 pm
    On one of our systems the adobe media encoder interface has gone missing. If I go File->Export->Media Encoder Premiere acts like the encoder is open (does not respond to any mouse clicks etc.) and if I press Enter it opens a “save as” window and then proceeds to encode the Movie to the whatever settings. But there is no Media Encoder Window open
    I have re-installed the whole production suite, but is still doing the same.
    Does anybody have any suggestions?
    Patty Fuller replied 12 years, 8 months ago 9 Members · 11 Replies
  • 11 Replies
  • Robert Hallion
    January 30, 2007 at 3:48 pm
    Is it possible that you ran duel monitors at once and now you aren’t running them? It maybe a strange question but if you did the encoder might have been opening on another screen, which isn’t there any more so it’s off your desktop.
  • Nicky Van der walt
    January 31, 2007 at 6:02 am
    Have and still are running dual monitors, but thinking about that now, the encoder might be sitting on the third monitor/video monitor.
  • Mike Velte
    January 31, 2007 at 12:10 pm
    Try reseting Premiere’s preference file; Hold down the Shift and CRTL keys while launching Premiere until a “Browse for folder” window pops up.
  • Karsten Runerheim
    April 27, 2007 at 8:19 am
    Hi!
    I am having the same problem. Did you ever find a solution for this?
    Mike Velte answered to my post that in worst case uninstall and reinstall Premiere. But I understand that this method was tried in your case but without success. Thankful for any input.
    Regards
    Karsten
  • Larry Melton
    May 9, 2007 at 9:25 am
    I just experienced this, of course when I was in a hurry to get something done…
    I had just worked with Matrox tech support (about another matter) and they had me install new drivers for my ATI graphics card, leading to a reconfiguration of my displays.
    When I went to use Matrox or Adobe Media Encoder to export from PPro, I had the same problems you’re describing. Someone here suggested that the window may be “hidden” on another display. I restored my monitors to their previous setup, and there it was. Thanks for the suggestion!
    Larry Melton
  • Filip Tomaszewski
    July 8, 2009 at 7:15 pm
    Hi
    I had a similar problem but this thread has helped me solve it. It was hiding on a disconnected screen (on OSX 10.5).
  • Run Rodriguez
    May 1, 2010 at 2:47 am
    I am experiencing a similar problem. When exporting from Premiere CS4, Adobe Media Encoder opens, however I cannot find the window. I recently got rid of a dual monitor system on my macbook pro and I’m pretty sure that’s the problem here. I deleted the premiere pro preferences in Users/[user] /Library/Application Support/Adobe/Premiere Pro/4.0. This did not help as I am still experiencing the problem. Any suggestions?
  • Run Rodriguez
    May 1, 2010 at 2:48 am
  • Run Rodriguez
    May 1, 2010 at 3:51 am
    I just found a solution:
    https://www.jonathanlaliberte.com/2007/10/19/move-all-windows-to-your-main-screen/
    This is a script that makes brings all active windows to the main screen.
    Works great.
  • Clifford Sonnentag
    October 23, 2012 at 8:02 pm
    SOLUTION FOR WINDOWS:
    In windows for all adobe products press ALT+SPACE and choose move. then the keyboard arrows will move your window anywhere you choose.
    This works for all windows windows.
