Activity Forums Adobe Premiere Pro Adobe Media Encoder Frame Rate Conversion Problem
  • Adobe Media Encoder Frame Rate Conversion Problem
    Posted by Michael Winger on April 6, 2010 at 9:39 pm
    I’m working with an AVCHD project in Premiere Pro CS4. I’d like to export the sequence as 30fps (since Vimeo prefers 30fps) with PNG compression. However when I try to export my sequence with this setting, I just get black video (with audio). If I change the frame rate to 29.97fps, the video export ok.
    (1) Has anyone else experienced this? If so, is there a fix?
    (2) Does uploading your videos to youtube/vimeo at an even number frame rate (rather than 29.97 or 23.976) make a big difference?
    Michael Winger replied 16 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
