Activity Forums Adobe Premiere Pro Adobe Media Encoder Fails to Launch
  • Adobe Media Encoder Fails to Launch
    Posted by Steve Allen on November 27, 2008 at 1:28 pm
    I have installed Master Collection CS4 and have been unable to export anything. When I go to Export Media to output my Sequence in Premiere I select my output options and then click ‘OK’. An “Exporting Data” dialog box pops up and closes and nothing more happens. It does not launch Media Encoder.
    So, I manually Launch Media Encoder and nothing is in its Queue. If I redo the export in Premiere with Media Encoder Open it does put an entry in the queue, but when I start the queue it errors with the Log entry:
    – Source File: C:\Users\Steve\AppData\Local\Temp\Export Test_7.prproj
    – Output File: C:\Users\Steve\Desktop\Kassie Video\Export Test.mov
    – Preset Used: Custom
    – Video:
    – Audio:
    – Bitrate:
    – Encoding Time: 10:26:35
    11/27/2008 8:20:55 AM : Encoding Failed
    Could not read from the source. Please check if it has moved or been deleted.
    The Source file IS there, the location listed is not my working directory.
    I would really like to see a final project out from CS4, any help is greatly appriciated.
    I am running Vista Home Premium with Service Pack 1
    Intel Quad Core, 3 Gig RAM
    Jamie Hurt replied 17 years, 9 months ago 3 Members · 2 Replies
  • Eddie Lotter
    November 27, 2008 at 3:28 pm
    Please apply the 4.0.1 update to CS4.
    Cheers
    Eddie
  • Jamie Hurt
    December 5, 2008 at 6:13 pm
    Also if you’re on a Mac, run Apple’s Disk Utility to Fix Permissions.
    I had the same error and was able to fix it by doing that.
    I had just installed a clean copy of my Mac OS, and a clean copy of CS4 – so the CS3 issue wasn’t the cause. It turns out my internal drives (job folders) were still assigned to the user from the previous OS…I thought I ran Disk Permissions earlier, but maybe it didn’t complete the process or ran into some error I didn’t pay enough attention to.
    -0
    Imagination is more important than knowledge. Knowledge is limited.
    – albert einstein
