Activity Forums Adobe After Effects Adobe Media Encoder and/or AE Pulldown?
  • Adobe Media Encoder and/or AE Pulldown?
    Posted by Matt Campbell on June 24, 2011 at 1:48 pm
    Can anyone tell me if AME can add in the correct pulldown for a 23.98 HD ProRes LT file conversion? I have a PR LT file at 24p (23.976) and need to encode to MPEG 2 HD with MPEG 2 audio, however they need 1080i60. So if I bring into AME and select MPEG 2 under format, and change the preset to 1080i29.97, will this add in the proper 3:2 pulldown to create the 29.97 frame or 60 interlaced fields per second file?
    I’m a compressor guy and don’t know Adobe stuff all that well, but compressor can’t handle this so I need to use AME or AE.
    Or should pulldown be adding in AE first then encoded to meet the specs?
    This is to air on a HD LCD in doctors offices, not for broadcast.
    OS 10.6.3, Mac Pro 2 x 2.66 ghz quad-core intel xenon, 16 gb ram, with BM Intensity Pro card
    Tudor “ted” jelescu replied 15 years, 3 months ago 2 Members · 4 Replies
  • Tudor “ted” jelescu
    June 24, 2011 at 6:06 pm
    To my knowledge AME does not do that- you will most likely need to handle the conversion in AE and then Encode.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Matt Campbell
    June 24, 2011 at 8:53 pm
    I gave it a whirl anyway just to see and after stepping through the quicktime file, it looks like its been added correctly. 3 clean frames and 2 interlaced ones.
    June 25, 2011 at 7:16 am
    Cool- good to know, thanks for sharing!
    Tudor “Ted” Jelescu
    Senior VFX Artist
    June 25, 2011 at 7:17 am
    Tudor “Ted” Jelescu
    Senior VFX Artist
