Activity Forums Adobe After Effects Adobe Media Encoder – AE Challenge
  • Adobe Media Encoder – AE Challenge
    Posted by Paul Nanna on February 11, 2013 at 10:19 pm
    We’ve been doing digital signage for 10 years now and are using CS4.
    All has been well exporting .mov files at an aspect rtatio of 2400 x 600 to fit our 3 panel wide displays (800 x 600 (x3).
    We have a client using CS6 who is building his own content.
    Appears he is not allowed by the PAR to export at 2400 x 600.
    The best it will do is 2000 x 600.
    I’ve installed an eval copy to confirm this and it is true.
    What happened?
    CS4 allows a direct export to Quicktime even with a pixel aspect set to 1.33.
    The new and improved will not allow this.
    Anyone know of an “over ride” or custom setting that will allow a .mov (H.264) outout of 2400×600, 1.33 aspect ratio in Adobe Media Encoder?
    Todd Kopriva replied 13 years, 7 months ago 3 Members · 6 Replies
  • Tero Ahlfors
    February 12, 2013 at 6:45 am
    Is there a reason you absolutely can’t use the mp4 H264 format?
  • Paul Nanna
    February 12, 2013 at 7:45 pm
    H.254 is the preference.
    We tried exporting using th Media Encoder at 2400×600.
    It bumps down to 2000×600 for the export.
    At one time, a ballon came up saying that the 2400×600(1.33) was out of the PAR specifications and would not be allowed.
    Again, with CS4, this was never a problem, although it did not utilize the Media Encoder as a output module that I can see.
    Looking to override the Media Encoder settings if possible.
  • Tero Ahlfors
    February 13, 2013 at 5:03 am
    The Quicktime version of H264 is getting pretty dated. The “proper” H264 mp4 has so much options for encoding.
  • Paul Nanna
    February 13, 2013 at 9:56 pm
    That would be fine… whatever works.
    Again, the problem is that teh Adobe Media Encoder will NOT ALLOW an export video file of the 2400 x 600 size.
    It dummies down to a 2000 x 600 output format.
    I’ll use whatever is available as long as 2400 x 600 can be output.
    I’m not codec “centric”. It just needs to be a quality codec that doesn’t require umpteen gigabytes for a 1 minute video file.
    Also…export from Adobe Media Encoder at 2400 x 600 (1.33)pixels aspect ratio.
  • Tero Ahlfors
    February 14, 2013 at 4:47 am
    Choose H264 from the dropdown menu and choose a high enough profile and level. Then TYPE the values in to the resolution settings because AME might freak out if you drag it to an invalid value.
  • Todd Kopriva
    February 19, 2013 at 9:32 pm
    If AME isn’t working as you need it to work, be sure to submit a bug report or feature request:
    https://www.adobe.com/go/wish
    You can submit the bug against Premiere Pro or After Effects—whichever one you use with AME most.
    After Effects team blog
