adobe illustrator tracing a text with vector pen..
In adobe illustrator cs4 i traced a text image with a vector pen tool as seen in the link below
https://www.battaliausa.com/sample2.png
When i render it in max the text is not all filled in, in the middle
as seen in the link below, the b is fine but the rest is not,,
https://www.battaliausa.com/sample1.png
The B and the line are fine but the rest need to be grouped or something
How to i merge the rest of the text togather
The out side of the a with the inside part,,
https://www.battaliausa.com/sample3.pngas you can see in this link the letter b and the line i traced is fine
the rest is not..
https://www.battaliausa.com/sample1.pngHope someone can under stand this..
thanks for any help
