Activity › Forums › Zaxwerks › Adobe Illustrator CS3 and Invigorator
  • Adobe Illustrator CS3 and Invigorator
    Posted by Mark Santella on October 13, 2007 at 9:36 am
    What version of invigorator/proanimator must you have to import from Adobe Illustrator CS3? Thanks for your help. By the way I love invigomany!!!
    Mark Santella replied 18 years, 11 months ago 2 Members · 2 Replies
  • Jon Okerstrom
    October 13, 2007 at 12:24 pm
    Hello FeelTheLove,
    You can use any version of Invigorator or ProAnimator. However, if you’re using an older version, you’ll need to export the art in a legacy Illustrator format. In any case, when you save the file, be sure the “use compression” box is unchecked.
    Does this help?
    Jon
  • Mark Santella
    October 13, 2007 at 6:03 pm
    Thanks Jon…that did the trick.
