Activity › Forums › Adobe Encore DVD › Adobe Encore – window not clickable
  • Adobe Encore – window not clickable
    Posted by Odil Ruzaliev on June 5, 2013 at 2:19 am
    I removed the main .*mov file from my computer and wanted to replace it on Encore with another one. But when the program opens, I get a window that says “locate asset”, and nothing on that window is clickable nor can I “cancel”, “skip” or do anything.
    Odil Ruzaliev replied 13 years, 3 months ago 2 Members · 3 Replies
  • Stan Jones
    June 5, 2013 at 3:29 am
    You replace the asset from within Encore. Try putting it back (!); then select it and use “replace asset.” Be sure the new file is not named the same.
    With it already deleted, I don’t know if you can get it to work.
    Stan Jones
  • Odil Ruzaliev
    June 5, 2013 at 3:47 am
    The first file is gone. I can’t add another asset or open the program. The window isn’t clickable, cancelable, very odd.
  • Odil Ruzaliev
    June 5, 2013 at 3:52 am
    OK, I just figured it out. Instead of double-clicking the project file, I rather started the Encore first and then clicked on the project name. In this case the locate the asset window became clickable.
