Activity Forums Adobe Encore DVD Adobe encore error: Invalid operation code 19
  • Adobe encore error: Invalid operation code 19
    Posted by Maria clara Marques on December 12, 2019 at 5:17 am
    I am trying to build my first bluray disc, and for weeks i am struggling with an error, that no matter what i do and what tests i make, it still shows up and i can`t find a solution anywhere!
    Note: i use to build dvds on encore for years, and never had this kind of issue befor.
    Error description: “error: Invalid operation code 19 encore primary video stream attributes must be consistent within playlist”
    anyone here knows what king of error is that, and how to fix it?
    Tom Kerr replied 3 years, 8 months ago 3 Members · 2 Replies
  • Jan Janowski
    January 2, 2020 at 1:06 pm
    Don’t have enough info in that screenshot to explain it, but I’d follow to see what file attributes are on the file it doesn’t like….
    Compare file attributes with Project Settings….
    I once encountered a file that didn’t import correctly in Encore…. I transcoded it to a different format Encore would use, and problem went away….
    Using CS6 here… All bets are off on CS5.5 and before….
  • Tom Kerr
    January 1, 2023 at 7:24 pm
    Ran into the same error 19 and had been using Encore CS5 for years with no difficulty.
    The MPEG2 Blu-ray export from Premiere was defaulting to PAL format. Specifying NTSC in the export video settings fixed the primary video stream error in Encore as well as problems playing in standard Blu-Ray players (it would exit the DVD and return to the player menu). Hope this helps others still using Encore.
