Activity › Forums › Adobe Encore DVD › Adobe Encore CS6 Crashes when Creating New Timeline
  • Adobe Encore CS6 Crashes when Creating New Timeline
    Posted by Jessica Mantheiy on June 21, 2012 at 4:25 pm
    Hi Everyone,
    I was messing around with Adobe Encore CS6 Blu-Ray features and I noticed that when you import your video assets and then try to create a timeline from it, Encore crashes. No matter if they are separate streams or just a standard .mov. Does anyone else have this issue? This has been reported on Adobe’s forums’ not too long ago and that the issue doesn’t occur in older versions on Encore:
    https://forums.adobe.com/message/4444132
    Any ideas?
    Jessica Muth
    Production Operations Manager
    Video Labs
    Rockville, MD
    301-217-0000
    jmuth@videolabs.net
    Olivier Grandi replied 13 years, 1 month ago 3 Members · 5 Replies
  • Stan Jones
    June 22, 2012 at 12:56 am
    The link you posted was an example of something that appeared to be broken in CS6 and okay in Encore CS5.1. It was not related to a crash upon creating a timeline from an imported asset.
    I do not experience the problem. But I’m on a PC, and I assume from your .mov example you are mac?
    Can you import as timeline? (I assume not.)
    Can you import an MPEG2 Bluray export from Premiere and create a timeline? (I’m looking for anything that works for your install, to rule out a bad install.)
    Stan Jones
  • Jessica Mantheiy
    June 22, 2012 at 11:05 am
    Haven’t tried to just import just as timeline. And yes, I have tried MPEG-2 Blu-Ray streams and it crashes then. It could be a bad install. If you say that you don’t have an issue with your version, then it would have to be a bad install.
    Jessica Muth
    Video Labs
    Rockville, MD
    301-217-0000
    jmuth@videolabs.net
  • Stan Jones
    June 22, 2012 at 11:18 am
    Another test is to import as asset an m2v from Encore’s library. Then try to make that a timeline.
    Stan Jones
  • Jessica Mantheiy
    June 23, 2012 at 2:20 am
    Tried m2v and had the same issue. Again, I think it is a bad install. But thank you to both of you for suggestions.
    Jessica Muth
    Video Labs
    Rockville, MD
    301-217-0000
    jmuth@videolabs.net
  • Olivier Grandi
    August 6, 2013 at 5:56 am
    I’m on Mac OS Lion and get the same issues with Encore CS6: crashes every time I import a timeline or try to create a timeline from an asset.
    I have another issue with PPro CS6 but concerning specifically exporting to AVCHD 50p: it doesn’t work with a compilation video error message.
    Before I was working on CS5 and all was great with no problem.
    You seem to think you had experienced personally a bad install of your CS6 package: had you fixed today and how ? Your experience is interesting for me of course.
    Thank you very much for all eventual explanation you could give me.
    See you soon.
    Olivier – Paris.
