Activity Forums Adobe Encore DVD Adobe Encore crashes upon menu creation
  • Adobe Encore crashes upon menu creation
    Posted by Guillermo Gomez on March 29, 2018 at 6:51 pm
    I have a problem: whenever I import a PSD menu into Encore CS5.1 for a Blu-Ray project, Encore just quits on me. The PSD file appears in the project’s Sources > Menus folder, but Encore crashes even if I hit Command-M (New Menu). I’ve tried deleting the preferences file from the library, but it still didn’t work.
    Mac OS 10.13.3 (17D47)
    iMac (21.5-inch, Late 2012)
    3.1 GHz Intel Core i7
    16 GB 1600 MHz DDR3
    Karen Nadalin replied 8 years, 2 months ago 3 Members · 7 Replies
  • 7 Replies
  • Stan Jones
    March 29, 2018 at 9:45 pm
    There were some issues with Macs and psd functions.
    Once imported, is the menu in the menu viewer?
    Can you import a menu from the library?
    You say you reset the library preferences; do you mean the Encore preferences?
    Was 5.1 working okay previously?
    Stan Jones
  • Guillermo Gomez
    March 29, 2018 at 10:07 pm
    No. There are no menus in the viewer.
    I don’t think so. Which library?
    I mean the .plist file.
    Yes, the last time I used it, a few months ago, I think before the upgrade to High Sierra.
  • Guillermo Gomez
    March 29, 2018 at 10:08 pm
    The debug database looks like this:
    AEResolveQTDataRefs true
    AME.EnablePresetDB false
    AME.EncoderHost.NoXMP false
    AME.amewrapper.donothide false
    AlwaysEnableDynamicLink false
    CloseAlwaysTimeoutInSeconds 300
    CloseIfContentionTimeoutInSeconds 15
    CompareMediaNodeRenderers false
    CreateLogFilesThatDoNotExist false
    DVDHighlightInterpolation 3
    DisableCUDADisplay false
    DisableMultiCamAcceleration false
    DisableNewMediaNodeRenderer false
    DisableSpeculativePrefetching false
    DumpPresetFilePassedToAME false
    DumpProject false
    DumpQueueOnDroppedFrames false
    Enable420Shaders true
    Enable422Shaders true
    EnableCUDAStabilizerWarpNode false
    EnableDogEars false
    EncoreBuildsleepMsecs 10
    ForceAIFRenderToCPUOnly false
    IgnorePlayerStop false
    LegacyQTCodecsAndGamma false
    MPEGDisableMultipleOpens false
    MinimumDelayBetweenFlushesInSeconds 1
    NumberOfInstancesBeforeContention 5
    PSmemUsagePercent 20
    Player.EnablePerfomanceStatics false
    PlayerAccelMode 3
    QTUseSourceGammaLevel false
    UseFrameBlendingForAME false
    UseMediacoreForLivelink true
    UseRemoteExporters false
    ame.pipeline.dumpframes false
    assert.enabled false
    enableChangeAuthorContextFromBuildPanel false
  • Stan Jones
    March 30, 2018 at 12:40 am
    The most frequent problem for new Mac OS is permissions. Make sure all Encore folders and files are read/write.
    This link is for Premiere, but may have some relevant info.
    https://blogs.adobe.com/kevinmonahan/2014/09/10/premiere-pro-cc-freezing-on-startup-or-crashing-while-working-mac-os-x-10-9-and-later/
    Not sure about Mac reset; see this link:
    https://helpx.adobe.com/x-productkb/global/troubleshoot-system-errors-freezes-mac.html
    Your issue reminds me of the “Photoshop -1” error that Mavericks users were getting (when it was new). The workaround was not to left click and to use right click or menu commands. Perhaps the parallel for you would be not using keyboard shortcuts?
    In any event, permissions have the best chance of fixing the problem.
    Stan Jones
  • Guillermo Gomez
    March 31, 2018 at 10:42 pm
    It also crashes when I use any method other than keyboard shortcuts. I even tried opening a previously made project with a menu in it, and while that old menu worked, it crashed every time I tried to create another menu in the same project. It works when I import a PSD file as an asset, but not as a menu.
  • Stan Jones
    April 1, 2018 at 12:33 pm
    Were your permissions set correctly? did you need to change any?
    Stan Jones
  • Karen Nadalin
    June 27, 2018 at 9:15 am
    Hi, Guillermo,
    I’m having the same problem using Encore CS5 with Mac High Sierra OS 10.13.4. This is driving me bonkers. Every time I try to add a new menu, whether with File > New > Menu, command-M, double-clicking one from the library, etc., it crashes the program. I’ve also tried trashing the preferences and even restarting the machine.
    Did you ever find a solution?
    Karen
