Activity › Forums › Adobe Encore DVD › adobe encore
  • adobe encore
    Posted by Joel Schlossberg on August 30, 2013 at 3:14 am
    i am using finalcutprox to create the video
    i tried to burn a blue ray disk and i am getting
    an error code3. than i sent the video to a harddrive
    and than i made the blue ray disk first 1o minute was
    ok tha it broke apart and stopped
    Daniel Ludwig replied 13 years ago 2 Members · 1 Reply
  • Daniel Ludwig
    September 2, 2013 at 2:50 am
    joel,
    so – what´s your question?
    it appears that your transcoded H264-file has been corrupted while encoding.
    you need to export the file again from FCP X and start transcoding (again) using compressor.
    IF you author the disc within encore you should be able to see if the stream is ok while passing the duration of 10min or not.
    cheers
    danny
