Activity › Forums › Adobe Encore DVD › Adobe Encore 1.0.0: Problem with image quality of menues
  • Adobe Encore 1.0.0: Problem with image quality of menues
    Posted by Svend5 on October 29, 2006 at 6:18 pm
    Hy! I created my menues in Photoshop and imported them in Encore 1.0. Everything looks fine, also in the preview mode. But on the final DVD, it looks bad, as if I used to small of a resolution. Which is not true, as my imagesize in Photoshop is PAL and the resoultion 200 dpi. What can i do?
    John Cuevas replied 19 years, 11 months ago 2 Members · 3 Replies
  • John Cuevas
    October 30, 2006 at 2:38 pm
    You should only need 72 DPI to create your menus. Did you create them at the PAL size? That would be 720 x576 rectangle pixels. Not sure what the conversion would be if you are using square pixels. If those aren’t correct, then the final output would appear muddy.
    Johnny Cuevas, Editor
    http://www.ckandco.net
  • Svend5
    October 31, 2006 at 12:06 am
    Yes, i created them in 576X720. I used Photoshop 7. Ok: how can i see if I used rectangle pixels and where can I set it up? In “imagesize”?
  • John Cuevas
    October 31, 2006 at 1:22 am
    If I recall correctly, PS7 only supports square pixels. From a quick search, start your menu in photoshop with a 768 x 576. That will resize to the correct aspect ratio upon importation into Encore.
