Activity Forums Adobe After Effects Adobe CS6 Camera Mapping Projection is Soft
  • Adobe CS6 Camera Mapping Projection is Soft
    Posted by Jon Shank on April 3, 2017 at 10:51 pm
    Hello, I am using CS6 to do this tutorial https://www.youtube.com/watch?v=8J1iwmjnpWo
    The projection ends up being soft and there is also a black jagged line in between the wall and sidewalk solids even when I overlap them.
    My comp is 1920×1080, resolution is set to full in ALL comps, and Shadow Map Resolution is at the Maximum 4000.
    Any ideas on what this could be?
    EDIT:
    I was able to get rid of the seam (the black jagged line) by turning off cast shadows on my two solid layers. However, there is still a noticeable loss in quality between the projection and the original image, even at 4000.
    Walter Soyka replied 9 years, 5 months ago 2 Members · 3 Replies
  • Walter Soyka
    April 4, 2017 at 4:38 pm
    You should get sharper projections at the cost of slower renders by using CS6’s Ray Tracing Renderer instead of the default Classic 3D renderer.
    Personally, I like the Rowbyte Camera Mapper plugin:
    https://aescripts.com/buena-depth-cue/
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Jon Shank
    April 4, 2017 at 6:38 pm
    What settings do you prefer for Ray Tracing for good quality?
  • Walter Soyka
    April 4, 2017 at 7:29 pm
    I’m not using the ray-tracer much these days. It was usually a balancing act between acceptable render time and acceptable quality. I use NVIDIA cards so I could turn it up pretty high without outrageously slow renders.
    Walter Soyka
