Activity › Forums › Adobe Audition › Adobe can’t find supported audio device
Posted by Don Hutcheson on August 27, 2009 at 7:38 pmI’ve installed Adobe Audition 3 and it is telling me it “can’t find a supported audio device”. I’m running it on a new quad core computer with VISTA. Isn’t there a driver on here that it can recognize?
Don
Frank Stone replied 14 years, 11 months ago 3 Members · 6 Replies -
Jesse Ruggles
August 28, 2009 at 8:58 pmHey Don,
Does this mean you got past your original DEP issue? What ended up working for you?
As to the audio hardware, Audition shouldn’t have any problem working with the sound card on your computer. Did you check to see what showed up in the list in Edit -> Audio Hardware Setup?
If nothing shows up, you might want to check for an updated driver for your audio card. If you don’t mind me asking, what computer do you have (is it a pre-built or something you built)? I know this might sound like a silly question, but outside of audition does your audio function properly? -
Don Hutcheson
August 30, 2009 at 1:45 amHey Jesse,
When you say “Edit/Hardware/Setup”, what program are you in when you select “Edit”? I can’t even get into Audition because I get the error message as the program is refusing to open.
As for the DEP issue, it appears to be resolved (I’m holding my breath until the program fully opens). An Adobe tech person suggested I (a)disable Norton 360 (b) disable “User Account Contols” (c) reboot and (d) reinstall Audition.
It worked; no more DEP error message. (Note: the tech who built my desktop PC also recommended I dump Norton 360 and go back to the basic version, and we did that on my desktop editor. 360 invents too many conflicts) and most editors disable any security software or create a separate identity w/o internet and security software anyway.
To anwer your other question, the laptop is an HP Pavillion with quad-core and 4G memory. It’s a back-up.Thank you,
Don
Hutch
Jesse Ruggles
September 3, 2009 at 8:03 pmAre you by any chance running a 64bit version of Vista on your laptop? Have you installed the Audition 3.0.1 patch? I dug around through a few different forums (including Adobe’s) and there seems to be a pattern of Audition 3 having noted compatibility issues with Vista 64bit. Installing the 3.0.1 patch seems to be a hit-or-miss solution to the issue for a few people. Do you know specifically what the audio card is in that laptop?
I’m sorry if I seem bring more questions than answers. I haven’t seen the issue myself (I’m running on Visa too, though 32bit), but I do want to help track down a solution to your predicament so I’m mainly trying to get some data to work with. -
Don Hutcheson
September 3, 2009 at 11:36 pmThanks Jesse. The computer is a 64-bit Quad-core with 4mb memory. I assumed since I ordered the software a month ago that it had the appropriate updated includes. Maybe not. I will try the one you suggested. I wanted Adobe 3 because of the music loops, but I might have to go back to Version 1 just to get any use at all. Do you hear of many users “upgrading” to Windows XP? A lot of people in my industry (broadcasters who need unflinching reliability) are going back to XP, or downloading software that allows you to run both systems and choose at boot-up.
Don
Hutch
Jesse Ruggles
September 3, 2009 at 11:47 pmA lot of people are going back to the stability of XP. The only thing you have to check on is that drivers exist for your hardware that support XP. Not all, but a growing number of laptops that were built specifically for Vista don’t have driver support for XP.
We still have XP for all our studio/production computers as well. The only exception is my laptop with Vista.
Hopefully the 3.0.1 update will fix the issue for you. -
Frank Stone
October 15, 2011 at 12:29 pmI too have experienced your problem not being able to open the application, or if the application opens telling me that my audio device is not configured properly.
When an error message appears “Adobe can’t find supported audio device” simply reboot your computer and if you are using a microphone, plug it in before you reboot your system.
I hope this helps resolve your problem.
Frank Stone
