Activity Forums Adobe Creative Cloud Adobe Bridge Temp Folder Won't Cooperate
  • Adobe Bridge Temp Folder Won't Cooperate
    Posted by Lucas Neeson on May 8, 2024 at 4:55 pm
    I originally set my Adobe Bridge temp folder location to a folder that I no longer use. I was able to reset it to the new folder, but now every time I load Bridge, it regenerates the older folder in the original location. Anyone know why this glitch is happening, or how to clear it? In preferences, the new folder location is set just fine, so not sure where this old directory is persisting in the Bridge config.
    Mads Nybo jørgensen
    replied 2 years, 4 months ago
    2 Members · 1 Reply
    May 8, 2024 at 5:22 pm
    Hey Lucas,
    I would be great to have a bit of info on what version software you are using, and hardware, please?
    Might be worth uninstalling bridge, and re-installing it, if that is where your problem is.
    But there is an infinite amount of possibilities, where the most likely is a mismatch between different software versions.
    Or, that all your Adobe packages are using the “old” folder, in which case you might want to trawl through them individually.
