Activity › Forums › Adobe Premiere Pro › Adobe Bridge (CS2)
  • Adobe Bridge (CS2)
    Posted by Eric Jurgenson on August 8, 2007 at 8:26 pm
    Has anyone taken the time to use Adobe Bridge as an adjunct to Premiere? As I get more and more XDCAM HD MXF footage on my system, I am finding Bridge invaluable for renaming, sorting, searching, viewing metadata, and basically acting as an overall database organizer for my clips.
    With XDCAM HD clips, it is usually easier to just copy the whole disk to a folder on the video drive than to transfer selects, so you typically end up with a lot of material to sort through later.
    I usually have Bridge set up in compact mode over my Premiere project window (my right hand monitor), so I can scroll rapidly through a single vertical column of nice large picons with my mouse wheel. Another minimize button on the interface shrinks it to just a big button showing the current folder, which sits very nicely over the large blank area at the top of the project window. This gets it totally out of the way when not in use.
    When I want to screen a clip, I simply drag it into the Premiere bin and double click on it to play in the source viewer. If I decide I don’t want that clip, I can immediately delete it from Premiere, keeping unneeded material out of the project.
    There are all kinds of other neat things you can do, like marking your shots with color flags, and doing batch renaming. Renaming individual clips is a snap (select and hit the space bar), although you want to do that before you bring them into Premiere; otherwise you will have to relink.
    It is especially handy for file based workflows, where clips are imported rather than captured – particularly XDCAM and P2.
    Next thing to do…figure out Version Cue.
    Alex Udell replied 19 years, 1 month ago 3 Members · 2 Replies
  • Aanarav Sareen
    August 9, 2007 at 4:53 am
    Eric,
    I hated Bridge 1.0 (CS2), but I am using Bridge CS3 on a more frequent basis. I am also a photographer, so it comes in VERY handy while working on images after a day’s shoot.
    – Aanarav
    Aanarav Sareen
    premiere@asvideoproductions.com
    https://www.asvideoproductions.com/techtalk
  • Alex Udell
    August 9, 2007 at 3:15 pm
    That’s intersting about MXF!
    The early version of Bridge irritated me because it’s preference structure was to generate thumbnails based in files size. This is acceptable for Stills, but horrible for video.
    If they have fixed this for video, and allowed you to set any thumbnail you want, it will start getting more intersting. I thought the Meta tagging was very cool for searching and cataloging.
    Problem I saw was that it was great for localized stuff. Not so great in workgroup. Your metadata is your own.
    Really need a Bridge Server / Bridge Client structure.
    Bridge server could constantly be indexing content and hold all the side card data.
    When you did a search in Bridge client it would use the Sever index giving you consisten results from any workstation in the group. NOW we’d be talking serious fun!
    Alex
