Activity Forums Adobe Premiere Pro Adobe and youtube
  • Adobe and youtube
    Posted by Matthew Lamond on August 20, 2008 at 11:45 pm
    2 things!
    First
    Whats the best export codec and settings to use to upload a video to youtube?
    Second
    Recently i have been exporting a video as Microsoft DV AVI and everything is fine. then i stick it into Divx Converter to compress it alot and not lose quality. It worked fine for me on friday but then today i exported the video again as a DV AVI and then used Divx Converter and right in the middle of my video i have a Still image in the video. well divx is just cutting out the still after a second and going back to the video and throwing my audio off by 10 seconds. HOWEVER i used the old clip through divx and didnt change a setting and it worked just fine. so i am doing something wrong in the exporting in Adobe. anyone have any ideas?
    Phocas Kroon replied 18 years ago 6 Members · 7 Replies
  • 7 Replies
  • David Dobson
    August 21, 2008 at 1:38 am
    YouTube is using flash now , but WMV works fine too
  • Harm Millaard
    August 21, 2008 at 10:13 am
    That is an oxymoron. Compression with DivX is lossy. You must have changed something.
    Harm Millaard
  • Phocas Kroon
    August 21, 2008 at 10:30 pm
    I have a good result with File>Export>AdobeMedia Encoder
    Format: Macromedia Flash Video (FLV)
    Preset: Custom
    Frame width: 320
    Frame height 240
    See: https://www.youtube.com/watch?v=LUzZajDrRQ0
    Good luck
    Phocas Kroon
  • Matthew Lamond
    August 21, 2008 at 11:53 pm
    Thanks! ill give it a try tommorrow here is what mine currently look like.
  • Dirk Hartmann
    August 22, 2008 at 10:40 am
    on german youtube help section, they commend mpg4 (wmv, divx) codec with 640×480.
  • Dan Asselin
    August 25, 2008 at 12:36 am
    Awesome video but the audio is particularly amazing. Could you share what settings you used for the audio with your flash.
    Thanks;
    Dan
  • Phocas Kroon
    August 25, 2008 at 9:33 am
    In PremierePro2 I used Flash 8-High Quality setting. There are no audiosettings but in the Audiocodec FlashVideo, MP3 and audio data rate 128 bps (stereo) are mentioned.
    The audio quality starts with the recording. We used a CD recording of this group. With 2 cameras the Bluegrass Boogiemen playbacked 8 times the tune. The edit is done with 16 tracks for the 16 camera positions.
    Phocas Kroon
