Activity › Forums › Adobe After Effects › Adobe After effects not smooth
  • Adobe After effects not smooth
    Posted by Peter Nagel on June 16, 2011 at 4:33 pm
    Hi CreativeCows,
    I just installed Adobe After Effects again. I made something very simple with Illustrator then I import it into adobe after effects and changed the rotation of 1 object so it rotates 45 degrees in 1 second. After rendering the movie and watching the avi I noticed that it didn’t rotate very smoothly. Does anyone know what I can change and how I can change it so the rotation will go smooth?
    Im using the basic options of After Effects now and haven’t changed anything in the options so far.
    Also I noticed when I import the Illustrator file it was one object however I need one object within the Illustrator file to rotate. So what I did was to import the Illustrator file without the object I wanted to rotate and import another file which was the object I wanted to rotate. It would be better if I can just import one file without having to import another file in order to rotate an object. Can I fix this by putting everything in another layer in Illustrator?
    Peter Nagel replied 15 years, 3 months ago 38,706 Members · 1 Reply
  • Peter Nagel
    June 16, 2011 at 5:37 pm
    Hi and thanks for the reply 😉 It kinda helped me. I remember from last time I used a Codec h.264 or something like that. Where can I change this? And this will effect the output of the movie right?
