Activity › Forums › Adobe After Effects › adobe after effects error 33::4
Posted by Lukas Kamp on January 21, 2018 at 5:37 pmi’m working on a movie for almost 5 months now and when i tried to open my project today it told me error missing data 33 § 4 even though nothing crashed and nothing new was changed or installed to the pc.
the only solutions i found online so far are auto save projects, which i dont have/ temp folder, which is empty for me/ restore points, which are also non existing on my pc and importing instead of opening, which also didnt work…
so all my work from the last half year is gone forever now or anyone knows what to do?Kevin Camp replied 8 years, 8 months ago 5 Members · 12 Replies -
Lukas Kamp
January 22, 2018 at 8:17 amthats what i meant when i said importing instead of opening, everytime i import it i get the same error message… any other ideas ? i might loose my job, i’m really worried…
Cassius Marques
January 22, 2018 at 10:54 amDid you remember turning off the default auto save function? OR did something get so corrupted that your folders are empty?
Because, dude, you’ve been working 5 months on a project and all you had was ONE project version file? That’s crazy!
Well sorry but as far as I’ve had this kind of errors, never once I could find a way to “uncorrupt” a project. Your best bet is to try and contact adobe and explain it to them. I’m not sure anyone else would be able to recover the file (and I don’t bet they will too)
Best of luck!
Cassius Marques
http://www.zapfilmes.com -
Walter Soyka
January 22, 2018 at 11:21 amPosts like yours are heartbreaking to read. I wish you the best of luck trying to recover your work.
This may be too late for you now, but hundreds or thousands of hours of work don’t belong in a single copy of a single file. Here’s my advice on protecting your After Effects work in the future:
https://www.renderbreak.com/2015/07/walters-field-notes-on-safeguarding-after-effects-project-files/This is a bit of a longshot, but have you ever rendered from your Ae project with Adobe Media Encoder? If yes, you might still have the temporary file that process creates. Search your computer for “tmpAEtoAMEProject” and see if you can find anything.
Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn] -
Lukas Kamp
January 22, 2018 at 2:27 pmi have one other file from november but i worked more lately so its pretty much nothing, i never had any problems with after effects in 5 years of working with it so i didn’t know it was neccessary to save it more than one time. No, i didnt turn autosave off but there are no autosave files or folders for me so i guess its turned off by default. I have no idea what caused the error, nothing ever crashed or something… ok i’ll try to contact adobe thanks for help….
Lukas Kamp
January 22, 2018 at 2:36 pmNo, I have never rendered with that. I never had any problems with After Effects so how should i know that i need to save more than 1 file… i don’t know what to do anymore.. it’s all over…
Walter Soyka
January 22, 2018 at 3:11 pm[Lukas kamp] “I never had any problems with After Effects so how should i know that i need to save more than 1 file…”
Lukas, AEP corruption is pretty rare, but there are any number of dangers with only a single copy of all your work. Accidental deletion, hard disk failure, theft, flood or fire, just a simple drop if you’re working on a laptop… there’s so much that can go wrong.
I’m so sorry I can’t help you better with this, but everyone should have a backup strategy for anything digital that’s important to them.
Walter Soyka
Daniel Waldron
January 22, 2018 at 5:39 pmLong shot here, but I noticed you said there is not even an auto-save folder. Is it possible you’re just not looking in the right place? When you go to your auto-save preferences, is it saving next to your AE file or going to a custom location?
Kevin Camp
January 23, 2018 at 12:22 amyou might look into some data recovery tools…. you may be able to recover a previously saved version of your file (before it was corrupted).
many of those tools will allow you to search for file type, so you could try and search for ae projects and hopefully find an earlier version of your project to recover.
Kevin Camp
Art Director
KCPQ, KZJO & KRCW -
Lukas Kamp
January 23, 2018 at 10:23 amOk i will try that, can you name some of those “data recovery tools” please ?
Lukas Kamp
January 23, 2018 at 10:26 amI just checked my auto save settings and they’re turned off by default so i guess there is not such a folder.
