Activity Forums Adobe After Effects Adobe After Effects CS6- 3D Camera Tracker/ Mocha CS6 Massive Problems
  • Adobe After Effects CS6- 3D Camera Tracker/ Mocha CS6 Massive Problems
    Posted by Simon Huang on February 26, 2014 at 11:52 am
    First of all, I would apologise if this is posted in the wrong section or something. I am new to this site 🙂
    Anways, here’s my problem.
    I have looked far and wide into the oceans from tutorials to forums etc, but I cannot seem to find the solution to the problem. I am pretty frustrated…
    I am using adobe after effects cs6 and I have decided to track my footage with 3D Camera Tracker. However, the mountain in my footage seems to shift back and forth abit. I know it is not a good footage to track as there are a few targets.
    please go to the following link.
    https://postimg.org/image/wi80qmwwb/
    The same thing has also happened with Mocha CS6. I have looked at dozens of tutorials but to no avail. This is what I have done:
    I used the “X Spline Layer Tool” and drew around the area that the mountain will appear in.
    I then tracked it with the button “track forward”. Everything was fine, everything was fully tracked.
    I then pressed “Export tracking data”- After Effects Transform data.
    In Adobe, I create a “Null”. Pasted the tracking data. Unticked “anchor points”. Parented the mountain to “null”.
    However, despite the excellent tracking in Mocha, the mountain still shifted around. I am on the brink of giving up. However, when I use a different element such as a fire, it tracks perfectly.
    https://postimg.org/image/qc1x0pbdp/
    Sorry, for the lengthy post. Please help. I am even willing to send my project so you professionals can help me out. Any advice/ tips/ or anything would be appreciated.
    Roland R. kahlenberg replied 12 years, 6 months ago 3 Members · 4 Replies
  • Roland R. kahlenberg
    February 26, 2014 at 4:00 pm
    You should track just the horizon – a single plane. Your tracking spline covers two different planes; the horizon and the water.
    Track again in mocha but restrict your tracking spline to the edge of the water and include some of the cloud/sky area.
    I suggest that you watch the following tutorials as you seem to not understand what planar entails –
    Start here – https://www.imagineersystems.com/videos/steve-wright-planar-tracking/view. Then look for the other tutorials in the “Learn mocha” series which were authored by Steve Wright.
    Then reinforce what you’ve learned with these other tutorials –
    https://www.imagineersystems.com/videos?tagFilter=Fundamentals+of+mocha&sortBy=Newest
    I’m also surprised that you’ve successfully linked to another object. There’s obviously some difference between these two objects that you’ve not shared.
    HTH
    RoRK
    Latest AE Workshop – MoGraph Intensity – Shapes & Text
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
  • Ross Shain
    February 26, 2014 at 5:25 pm
    Yes – as Roland suggests, you need to track 1 plane in mocha. The water is obviously moving on a different plane than the clouds in the background and will throw off your track.
    I would suggest tracking just the clouds in a smaller shape if you are trying to do sky replacement.
    mocha V3 has a 3D solver in which the user tracks multiple planes, than does a camera solve on the selected planes, but first you need to get a good grasp of how planar tracking works.
    Best,
    Ross
    Ross Shain
    Imagineer Systems
    http://www.imagineersystems.com
  • Simon Huang
    February 27, 2014 at 9:37 am
    Thanks for the reply. I’ll give it a try. But, how do you differentiate one plane from the another? I thought you simply create a spline or a box around the area, and place the mountain in the area that you tracked in Mocha.
    February 27, 2014 at 1:24 pm
    [Simon Huang] “But, how do you differentiate one plane from the another?”
    Your question is incredibly basic – it is something you should know prior to tracking with mocha. You were provided with a couple of URLs to help you in this area. Please do the neccesary.
    HTH
    RoRK
