Activity Forums Adobe After Effects Adobe After Effects CS5.5 wont install
  • Adobe After Effects CS5.5 wont install
    Posted by Eddie Dorsey on July 22, 2013 at 4:09 am
    Ok, so I tried to install Adobe After Effects CS5.5 tonight.
    Here’s what I tried it on: my Acer Aspire 5253 laptop. AMC Dual-Core C50, 4 GB DDR3 RAM, 320 GB HD, Windows 7 64-bit Home Premium.
    Got this and I couldn’t tell ya what any of this means. If anyone here can, I’d appreciate it. It got this error code early on in the install, so that’s why the error message is so long.
    Exit Code: 7
    ————————————– Summary ————————————–
    – 0 fatal error(s), 57 error(s), 55 warning(s)
    WARNING: DW065: Display requirements not met for {E82097B9-A3B8-404A-9A92-AC16A8AC9576}
    WARNING: DW065: Display requirements not met for {C61B093E-259E-45D8-B9B6-24630A700398}
    ———– Payload: {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86 1.0.0.0 ———–
    ERROR: Error 1402.Could not open key: UNKNOWNComponentsDA42BC89BF25F5BD0AF18C3B9B1A1EE891785D291CBB3CC40AB8659C8E48CCC2. Verify that you have sufficient access to that key, or contact your support personnel.
    ERROR: Install MSI payload failed with error: 1603 – Fatal error during installation.
    MSI Error message: Error 1402.Could not open key: UNKNOWNComponentsDA42BC89BF25F5BD0AF18C3B9B1A1EE891785D291CBB3CC40AB8659C8E48CCC2. Verify that you have sufficient access to that key, or contact your support personnel.
    WARNING: DW036: Payload cannot be installed due to dependent operation failure
    ERROR: DW050: The following payload errors were found during install:
    ERROR: DW050: – Adobe ExtendScript Toolkit CS5.5: Install failed
    ERROR: DW050: – Microsoft_VC90_ATL_x86: Install failed
    ERROR: DW050: – Recommended Common Fonts Installation x64: Install failed
    ERROR: DW050: – AdobePDFL x64 CS5: Install failed
    ERROR: DW050: – DynamiclinkSupport: Install failed
    ERROR: DW050: – Microsoft_VC80_MFCLOC_x86_x64: Install failed
    ERROR: DW050: – Adobe XMP Panels CS5: Install failed
    ERROR: DW050: – Pixel Bender Toolkit: Install failed
    ERROR: DW050: – Photoshop Camera Raw (64 bit)_6.3_AdobeCameraRaw6.0All-x64: Install failed
    ERROR: DW050: – Photoshop Camera Raw: Install failed
    ERROR: DW050: – Camera Profiles Installer: Install failed
    ERROR: DW050: – Adobe Extension Manager CS5.5: Install failed
    ERROR: DW050: – Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll: Install failed
    ERROR: DW050: – AdobeColorCommonSetRGB: Install failed
    ERROR: DW050: – Microsoft_VC80_CRT_x86_x64: Install failed
    ERROR: DW050: – Adobe Device Central CS5.5: Failed due to Language Pack installation failure
    ERROR: DW050: – AdobeMotionPicture CS5.5: Install failed
    ERROR: DW050: – Adobe After Effects CS5.5 Third Party Content: Install failed
    ERROR: DW050: – Photoshop Camera Raw (64 bit): Install failed
    ERROR: DW050: – Microsoft_VC90_MFC_x86: Install failed
    ERROR: DW050: – Adobe Media Encoder CS5.5 X64: Install failed
    ERROR: DW050: – AdobeTypeSupport CS5: Install failed
    ERROR: DW050: – Adobe CSXS Infrastructure CS5.5: Install failed
    ERROR: DW050: – Adobe After Effects CS5.5 Support: Install failed
    ERROR: DW050: – AdobeHelp: Install failed
    ERROR: DW050: – Required Common Fonts Installation x64: Install failed
    ERROR: DW050: – Microsoft_VC90_ATL_x86_x64: Install failed
    ERROR: DW050: – Adobe Story: Install failed
    ERROR: DW050: – Microsoft_VC90_CRT_x86_x64: Install failed
    ERROR: DW050: – Microsoft_VC80_CRT_x86: Install failed
    ERROR: DW050: – Adobe Device Central CS5.5_DeviceCentral3.5LP-en_US: Install failed
    ERROR: DW050: – AdobeCMaps x64 CS5: Install failed
    ERROR: DW050: – AdobeTypeSupport x64 CS5: Install failed
    ERROR: DW050: – Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All: Install failed
    ERROR: DW050: – Microsoft_VC90_MFC_x86_x64: Install failed
    ERROR: DW050: – AdobeOutputModule: Install failed
    ERROR: DW050: – Microsoft_VC90_MFCLOC_x86: Install failed
    ERROR: DW050: – AdobePDFL CS5: Install failed
    ERROR: DW050: – AdobeCMaps CS5: Install failed
    ERROR: DW050: – Adobe After Effects CS5.5 Presets: Install failed
    ERROR: DW050: – Adobe After Effects CS5.5 Third Party Content Wrapper: Install failed
    ERROR: DW050: – Adobe After Effects CS5.5_AdobeAfterEffects10.5en_USLanguagePack: Install failed
    ERROR: DW050: – Microsoft_VC80_MFC_x86_x64: Install failed
    ERROR: DW050: – AdobeColorVideoProfilesAE CS5.5: Install failed
    ERROR: DW050: – Adobe Player for Embedding x64 3.1: Install failed
    ERROR: DW050: – Adobe SwitchBoard 2.0: Install failed
    ERROR: DW050: – Microsoft_VC80_MFC_x86: Install failed
    ERROR: DW050: – Adobe Player for Embedding 3.1: Install failed
    ERROR: DW050: – Microsoft_VC80_MFCLOC_x86: Install failed
    ERROR: DW050: – AdobeJRE: Install failed
    ERROR: DW050: – Adobe After Effects CS5.5: Failed due to Language Pack installation failure
    ERROR: DW050: – Suite Shared Configuration CS5.5: Install failed
    ERROR: DW050: – Adobe Bridge CS5.1: Install failed
    ERROR: DW050: – Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All: Install failed
    Todd Kopriva replied 13 years, 1 month ago 2 Members · 1 Reply
