Activity Forums Adobe After Effects Adobe After Effects CS3 keeps crashing frequently
  • Adobe After Effects CS3 keeps crashing frequently
    Posted by Dhinesh Kumar on January 23, 2009 at 10:25 am
    We are using adobe after effects CS3 in our production system. From last monday, the after effects hung and the production comes to a halt. The frequency is high. When AE hangs, the nonresponsive program window with the “Send Error” and “Dont Send” buttons is displayed. Once we click the “Dont send”, the AE resumes to normal condition and continue processing the jobs.
    When analyzed the windows event viewer, we have observed that the AE crashes with 2 different error code 1000 and 1002. Out of the total 12 crashes happened over the past 5 days, 10 crashes are due to error code 1000 and 2 crashes due to the error code 1002.
    System Configuration
    The AE CS3 is installed in a Windows XP SP2 host available in a blade server (Intel based Dual Quad Core processor based) virtualized through VMWare. This particular host where CS3 is installed has 2GB RAM, 2 CPU of 2.5GHz each.
    Given below is the complete snap shot of the 1000 and 1002 error from windows event viewer:
    ERROR CODE 1000 DETAILS
    Date: 1/19/2009
    Time: 5:56:02 AM
    Type: Error
    Source: Application Error
    Category: None
    Event Id: 1000
    User: N/A
    Computer: MAG-RENDER01
    Description
    Faulting application afterfx.exe, version 8.0.0.298, faulting module afterfx.dll, version 0.0.0.0, fault address 0x00139874.
    For more information, see Help and Support Center at https://go.microsoft.com/fwlink/events.asp.
    Data
    In Bytes:
    0000: 41 70 70 6c 69 63 61 74 Applicat
    0008: 69 6f 6e 20 46 61 69 6c ion Fail
    0010: 75 72 65 20 20 61 66 74 ure aft
    0018: 65 72 66 78 2e 65 78 65 erfx.exe
    0020: 20 38 2e 30 2e 30 2e 32 8.0.0.2
    0028: 39 38 20 69 6e 20 61 66 98 in af
    0030: 74 65 72 66 78 2e 64 6c terfx.dl
    0038: 6c 20 30 2e 30 2e 30 2e l 0.0.0.
    0040: 30 20 61 74 20 6f 66 66 0 at off
    0048: 73 65 74 20 30 30 31 33 set 0013
    0050: 39 38 37 34 0d 0a 9874..
    In Words:
    0000: 6c707041 74616369 206e6f69 6c696146
    0010: 20657275 74666120 78667265 6578652e
    0020: 302e3820 322e302e 69203839 6661206e
    0030: 66726574 6c642e78 2e30206c 2e302e30
    0040: 74612030 66666f20 20746573 33313030
    0050: 34373839 0a0d
    ERROR CODE 1002 DETAILS
    Date: 1/18/2009
    Time: 10:20:54 AM
    Type: Error
    Source: Application Hang
    Category: [101]
    Event Id: 1002
    User: N/A
    Description
    Hanging application AfterFX.exe, version 8.0.0.298, hang module hungapp, version 0.0.0.0, hang address 0x00000000.
    Data
    In Bytes:
    0008: 69 6f 6e 20 48 61 6e 67 ion Hang
    0010: 20 20 41 66 74 65 72 46 AfterF
    0018: 58 2e 65 78 65 20 38 2e X.exe 8.
    0020: 30 2e 30 2e 32 39 38 20 0.0.298
    0028: 69 6e 20 68 75 6e 67 61 in hunga
    0030: 70 70 20 30 2e 30 2e 30 pp 0.0.0
    0038: 2e 30 20 61 74 20 6f 66 .0 at of
    0040: 66 73 65 74 20 30 30 30 fset 000
    0048: 30 30 30 30 30 00000
    In Words:
    0000: 6c707041 74616369 206e6f69 676e6148
    0010: 66412020 46726574 78652e58 2e382065
    0020: 2e302e30 20383932 68206e69 61676e75
    0030: 30207070 302e302e 6120302e 666f2074
    0040: 74657366 30303020 30303030 30
    Has anyone come across the AE Crash with these error codes? Please provide us some info on what might be the reason and the solution.
    Thanks and Regards,
    Dhinesh Kumar P
    Bob Edwards replied 16 years, 10 months ago 3 Members · 3 Replies
  • Dhinesh Kumar
    January 23, 2009 at 5:33 pm
    Hi Dave,
    Thanks for the response. We are not importing any of the file formats that you have mentioned in AE. But we do generate the mp4 and H.264 files as outputs.
    The machine that crashes in our production system is not actually rendering the outputs. This system just modifies the aep file and adds the output files in the render queue through the .jsx scripts. We use network rendering capability of the AE CS3 to render the outputs through a set of rendering machines watching this shared folder in the network.
    Moreover, the system has been in production for over 2 months. The crash started out of blue only from 18th Jan.
    I’m wondering whether it could be due to any change in the network parameters in the production environment as our setup involves the network access.
    Thanks and Regards,
    Dhinesh Kumar P
  • Chris Wright
    January 23, 2009 at 9:50 pm
    in every instance of AE I have ever seen crashing and also being fixed is starting with a basic fresh install, no extra cards, accelerators, or 3rd party systems and then painfully adding each new 3rd party component back in one at a time, restarting and checking for stability. Everyone always finds out that it’s hardware based once the software is re-done.
  • Bob Edwards
    November 6, 2009 at 6:26 pm
    I’ve had this issue for a long time as well and I’ve run the “death to Adobe” script (which removes every bit of Adobe software) and re-installed and still had a very similar issue to this. Also, I’ve had this issue most recently working with Targa image sequences, so, though the interlace thing is really helpful, it’s not really the source of my problems.
    Did you ever find an answer to your issue???
