Adobe AE CS4 Error. Need sagely advice
Hello all
I’m trying to run Adobe After Effects CS 4, which is starting correctly expect for this error message that comes up…
“After Effects error:plug-in “C:\Program Files\Adobe\Adobe After Effects CS4\support files\ Plug-ins\CFHDIO.aex” could not be loaded (126).
(48::46)”Not having the tech knowledge to understand this error, i continue on till the programme loads up.
Problem occurs when i can’t seem to play any footage that i import. The file appears there but then when i try to play or preview the footage, it’s won’t play anything.
Please help
