Activity Forums Adobe After Effects Adobe AE Black Screen (Project Viewer)
  • Adobe AE Black Screen (Project Viewer)
    Posted by Stephen Curry on December 31, 2016 at 1:51 pm
    I would like to pick some people’s brains on a phenomenon that occasionally happens to me using AE.
    This has happened in AE CS 5, 5.5, 6 and CC 2015.
    Phenomenon:
    When importing (almost always a video clip…well only video clips that I know of), those clips will be displayed in the Comp View Window as Black. The audio is still there, and you can move your color picker throughout the Comp View Window and it will pick up the colors from the video but the viewer itself only displays black.
    I’ve seen posts where this is called the Adobe Black Screen of Death…(a take off of Microsoft’s Blue Screen of Death)
    What I have noticed about this phenomenon (my new word of the day) is that it is something to do with individual projects and how AE translates or decodes the video, and is not the video itself. (Although sometimes converting the video to another format solves the issue for the project you’re working on, its doesn’t resolve the bug in and of itself as it will eventually happen again.)
    Example:
    I was working with an Opener project file from VideoHive created in an older version of AE. The Opener project file and all the elements of that opener worked flawlessly. However, when I imported some of MY video clips (both drag and drop, double click, and File>Import) to add my clips to the project, those clips would only display as black in the Comp View Window. (when I scrubbed, when I refreshed, when I resized, when I closed the panel and reopened it)
    It was driving me crazy. So, I saved and rebooted. No luck.
    I converted those clips to various other formats. No luck.
    Purged memory. No luck.
    Screamed at computer. No luck.
    Nothing instills panic like losing hours of work….
    However, I still thought it odd that the project elements worked, but my video wouldn’t.
    So, I rebooted and launched AE again but this time, to a clean new project.
    I then ‘imported’ my video files (in their original .mp4 format) to this newly created project and they worked.
    I closed that new project and opened my previous opener project again, imported my video and it was still black. ;.-(
    To make a long story longer I had to render my VideoHive Opener as a separate video clip, close out that opener project, go back to my new clean project, import my video, import my rendered opener clip, and continue on my way….(downside is that if I needed to make changes to the Opener I had to flop back and forth between projects)
    So, my point and or question(s)
    It’s obviously not the videos as they worked fine inside of one project but not another (even thou sometimes converting the video solves the issue).
    -Is there something within certain projects (and I know the variables are endless) that could be causing this.?
    -Is it How Old version of AE saves file [vs] How Newer version of AE imports and converts file?
    -Is it a bug in the video import process? (drag and drop or File>Import)
    -Is this the $64,000 question?
    -If it’s a codec issue why would the clips work in the new clean project and not the established project?
    -Is this some evil easter egg from Adobe?
    -Anyone have a (it always works) solution?
    -Does Adobe have a fix…if they do it’s not working.
    Jenny Conway replied 9 years, 8 months ago 4 Members · 9 Replies
  • 9 Replies
  • Chris Wright
    December 31, 2016 at 8:50 pm
    purging memory ever fix this?
  • Stephen Curry
    December 31, 2016 at 9:04 pm
    No, I mention that in my post….for the life of me I cant figure out why it does this periodically…but its a nusiance.
  • Chris Wright
    December 31, 2016 at 11:44 pm
    oops, I meant to say purge disk cache
    any LUT’s applied?
    it sounds like a combination of transitions or effects that causes the issue.
    you could narrow it down by adding them back one by one until the error appears again.
  • Walter Soyka
    January 3, 2017 at 9:12 pm
    [Dave LaRonde] “Well, AE CC 2017 IS A DOG. DO NOT USE IT. Any questions?”
    Dave, I think you make it very hard for users to understand what the real problems are in CC 2017 when you blame it for everything. Stephen specifically mentions that this problem occurs in CS5, 5.5, 6 and CC 2015 in his original post.
    Personally, Stephen, I’d try clearing the conformed media caches (NOT the same as Purge All Memory & Disk Cache).
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Stephen Curry
    January 3, 2017 at 10:05 pm
    Thanks for the tip Walter,
    I guess I’m not familiar with Conformed Media Cache.
    How do you clear it / them?
    Steph
  • Walter Soyka
    January 3, 2017 at 10:11 pm
    Look at the lower half of the window at Edit > Preferences > Media & Disk Cache. You can clear both the conformed media cache database and the cache itself here.
    The conformed media cache is shared with Premiere Pro. It’s a part of the MediaCore framework that Adobe applications share and allows them to more easily handle playback of certain kinds of media. I wouldn’t normally expect this to cause the problem you’re describing, but I think this is the next reasonable troubleshooting step for a media problem such as you describe.
    Walter Soyka
  • Jenny Conway
    January 25, 2017 at 4:24 pm
    Not sure if this helps but, after upgrading to AE 2017 and rendering from AE, I found my QT renders showed black (when viewed in QT 7 and wouldn’t read at all in QT 10). I tried exporting to Media Encoder 2017 only to have it crash repeatedly.
    But, what I found out, as I was trouble shooting: I can render out of AE 2017 to a QT file and, while it can’t be viewed in QT or be imported into AVID, if I then run it through Encoder 2015, the file is now playable in QT and able to be imported into Avid.
    It’s a pain to do the extra step but it’s possible your videohive assets could be treated in the same way?
    (I only upgraded in order to open a file sent to me, but I know I’ll stick w AE 2015 for the near future.)
    Jenny
  • Walter Soyka
    January 25, 2017 at 4:58 pm
    [Jenny Conway] “after upgrading to AE 2017 and rendering from AE, I found my QT renders showed black (when viewed in QT 7 and wouldn’t read at all in QT 10)”
    I wonder if you’re rendering to CineForm? Can you post a screenshot of your Ae output module settings?
    Walter Soyka
  • Jenny Conway
    January 25, 2017 at 6:05 pm
    Great question! I wasn’t rendering to Cineform but that made me check my Output Modules and it looks like AE 2017 alters your previous settings. It changed it from an Avid DNxHD Codec to a DNxHR/DNxHD.
    I’m attaching a screengrab that compares output module settings and the pulldown re: the Avid codec settings (even the list has changed) in case that helps anyone.( I’ll also check with Avid to see if they’ve updated their codec).
    I did a test render in AE 2017 w the corrected codec and it works!
    Many thanks, Walter!
    Jenny
