Activity › Forums › Adobe After Effects › adjustments layer problem
Posted by Payman Naderi on September 24, 2017 at 11:42 pmhello guys
i have problem with adjustment layer
there is no icon in front of that
and after making that it become solid layer
i need to use the adjustment layer on top of all my layers but it’s white.payman naderi
payman.naderi744@gmail.comPayman Naderi replied 8 years, 12 months ago 3 Members · 4 Replies -
Greg Gesch
September 25, 2017 at 12:12 amHi Payman, if you look at the top of the panel you can see a row of icons, select the second one in from the end – the half white circle. (This can turn any layer into an adjustment layer.)
Payman Naderi
September 25, 2017 at 11:04 amtnx greg for your reply.but if you notice to layer,you will see that the front of adjustment layer is not check able.
when i make a solid layer on top,the icon place appear then i can select it as a solid or adjustment layer,but when i make a layer on top the other layer the iicon place with a half white circle disappear, -
Cassius Marques
September 25, 2017 at 12:54 pmThe layer below (2) is trying to use the adjustment layer as a matte(you can’t have both). Change that (or put something in between) and you should see things as you’re expecting.
Cassius Marques
http://www.zapfilmes.com -
Payman Naderi
September 25, 2017 at 9:38 pmwonderful,yes
you are true,the trkmat when is on (alpha matt) will refer to upper layer as a solid or something inside.when the layer is adjustment layer (and there is nothing inside) and on layer below trkmat is referring on alpha the logic of after effects changes the adjustment layer to solid.
tank you so much.
i understand the logic from your short answer.
