Activity Forums Adobe Photoshop Adjustment layers with filters?
  • Adjustment layers with filters?
    Posted by Espen Jakobsen on July 18, 2009 at 1:23 pm
    Is there any way to put filters on adjustment layers like in After Effects, or do I have to merge alle the layers? For instance if I want to add an edge blur to the whole image, do I have to merge it?
    Mike Jones replied 17 years, 2 months ago 2 Members · 1 Reply
  • Mike Jones
    July 18, 2009 at 5:03 pm
    You can apply filters to an adjustment layer, just like you would on a normal one, However if you are using a mask on your adjustment layer you need re-apply it when you add the filter. One way to do this is to select the mask before you apply the filter.
    If you are used to the ‘editable’ filters of AE then i suggest converting layers to smart objects and using ‘smart filters’ as these are live editable and maskable.
    Not sure if this is any help.
    Mike Jones LBIPP
    Marine Photographer
