Activity Forums Adobe After Effects Adjustment layers inside collapsed precomp stopped working after I made a duplicate precomp
  • Adjustment layers inside collapsed precomp stopped working after I made a duplicate precomp
    Posted by Konrad Grzegorzewicz on May 9, 2018 at 10:18 am
    I have a glass pane precomp consisting of three adjustment layers with some blur, transform, tint effects etc.
    In the main composition I have ‘collapse transformations’ checkbox ticked so it works as expected i.e. the adjustment layers inside the glass pane affect the layers in the main comp. Now I tried to make another glass pane based on the first one so I duplicated it in the Project panel, pulled into the main comp as a layer and it doesn’t work, i.e. there’s no visible effect. I do have ‘collapse transformations’ checked as well.
    One thing I noticed, the old glass pane precomps have small dashes in Motion Blur checkbox, and Blend Mode, the new (not working) one has Blend Mode = Normal and empty checkbox.
    Is this a bug or do I do something wrong?
    Konrad Grzegorzewicz replied 8 years, 3 months ago 2 Members · 2 Replies
  • Cassius Marques
    May 9, 2018 at 1:03 pm
    If you already checked collapse transformations, perhaps remove any effects/layer styles you applied. They must go in the layers inside. Can’t be applied to the comp itself.
    Cassius Marques
    http://www.zapfilmes.com
  • Konrad Grzegorzewicz
    May 9, 2018 at 1:45 pm
    That was it. I just noticed I had tint applied to the comp itself indeed. Removed it and the glass works as expected now.
    Thank you, good man! 😀
