Activity Forums Adobe After Effects Adjustment Layers in CS4
  • Adjustment Layers in CS4
    Posted by Dan Callahan on June 22, 2010 at 9:54 pm
    I have imported a project from photoshop and have animated parts of it to slide in under a mask that has been applied using an adjustment layer. The adjustment layer is on the top level of the composition, but the mask therein is not affecting any of the layers below it; regardless of where it is placed within the composition. All the layers are checked as 3D, so I am out of ideas as to what could be going on at this point.
    Are there any instances where Adjustment layers do not affect the layers below it? Also, any suggested workarounds to this issue? Thanks in advance.
    Tudor “ted” jelescu replied 16 years, 3 months ago 2 Members · 1 Reply
  • Tudor “ted” jelescu
    June 22, 2010 at 10:39 pm
    In AE a mask applied to an Adjustment layer will determine the area in that layer in which any effects applied to it affect the layers under.
    The mask will work as a mask on 2d layers if those layers use track matte from the Adjustment layer.
    You may want to precomp your layers and draw the mask on the precomp.
    Tudor “Ted” Jelescu
    Senior VFX Artist
    Bucharest, Romania
    http://www.ennstudio.ro
