Activity Forums Adobe After Effects Adjustment Layers in CS4
  • Adjustment Layers in CS4
    Posted by Dan Callahan on June 24, 2010 at 4:58 pm
    I am looking to have a text object warp and bend based on its position in 3d space, sort of like a 3d flowing effect. For example, when the text’s orientation is changed 180*, the text would bend away from the viewer to follow the path’s anchor point, rather than rigidly moving as a single object. I only want to bend the text based on its x and z variables.
    Is there a native effect in AE cs4 that I could use to achieve this effect? Or would I need to use expressions or even a completely different feature to achieve it?
    Or, would this perhaps be easier to achieve if I converted the text to an object? Please give me some advice.
    Thanks in advance.
    Todd Kopriva replied 16 years, 3 months ago 2 Members · 3 Replies
  • Todd Kopriva
    June 24, 2010 at 6:09 pm
    I know that you asked about After Effects CS4, but I’ll offer this suggestion anyway: This sounds like a great job for FreeForm, which comes with After Effects CS5.
    FreeForm bends 3D layers based on meshes or displacement maps, and I think that it would be relatively easy to create a displacement map based on the parameters that you described.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Dan Callahan
    June 24, 2010 at 7:01 pm
    Sounds great, but is there an alternative workaround for cs4 that I could look into?
  • Todd Kopriva
    June 24, 2010 at 9:06 pm
    FreeForm is available for After Effects CS4, though you’d have to pay for it separately.
    A different approach, perhaps…
    You mentioned bending, which is why I suggest a 3D warping/deforming effect, but you could do much of what you describe with 3D per-character text animation. You could use an expression selector to target and animate the text characters based on certain parameters.
