Activity Forums Adobe After Effects Adjustment Layers from Photoshop???!! 0_0
  • Adjustment Layers from Photoshop???!! 0_0
    Posted by Francesca Bini on August 1, 2009 at 8:57 am
    Hello again :p sorry for being so needy of help…I ran into another issue and no matter how time I spent looking on the internet for an answer I could not find it!
    I have several layers in my photoshop file. I import them into after effects but the adjustment layers (hue/saturation and curves) don’t show!! they look like one solid layer (I forgot if black or white…) and to see through I have to switch them off.
    Is there a way to import my adjustment layers!!?? I also tried to just make new adjustment layers in AE copying over the values. This works for the Hue and Saturation ones which have numbers as values, but I can’t do this with the Curves adjustment layers! Is there a way to see the numeric values of those layers so that I can copy them over?
    Thank you so much for your time
    I really appreciate your help
    Marcus Leite replied 17 years ago 3 Members · 3 Replies
  • Todd Kopriva
    August 2, 2009 at 12:40 am
    What versions of After Effects and Photoshop are you using?
    After Effects CS3 and CS4 each contain a complete version of the Photoshop rendering system inside it, so adjustment layers (and almost everything else) should come across.
    For a list of things that transfer over, see “Preparing and importing Photoshop files”.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • Francesca Bini
    August 2, 2009 at 8:33 pm
    I have CS4. I actually tried to just recreate the adjustment layers directly in After Effects. The problems are the CURVES!!!! I could find a way to visualize them as number (and not graph) in Photoshop so that I could copy the values over in After Effect…
    thank you though 🙂
  • Marcus Leite
    September 6, 2009 at 4:20 am
    K i am having the same results. I am useing cs4 across the board and my photoshop files are importing as black layers. I Been trying to trouble shoot this for hours not and can’t find the problems. Any help would be most welcome.
    Thanks.
    Marcus Leite
