Activity Forums Adobe After Effects Adjustment layer
  • Adjustment layer
    Posted by Laputa on June 6, 2006 at 12:23 pm
    I use add adjustment and apply effect adjust color balance. But it only works for the text in AE not other graphics there.
    Do anyone know what wrong?
    Mylenium replied 20 years, 3 months ago 3 Members · 2 Replies
  • Steve Roberts
    June 6, 2006 at 3:40 pm
    If you want to affect more than one layer, you should:
    1)Create an adjustment layer (layer>new>adjustment layer).
    2)Next, apply the effect to the adjustment layer. This effect will then be applied to all layers below the adjustment layer.
    Does that help?
  • Mylenium
    June 6, 2006 at 3:43 pm
    No idea. Possibly you are using certain blendmodes that do not reflect adjustments (e.g. Add or Screen) because the only add up luminosity. Other than that check if any of your layers are guide layers or your alpha channel actually registers as non-transparent in the areas that you want to be affected.
    Mylenium
    [Pour Myl
