Activity Forums Adobe After Effects Adjustment Layer with Blur and Feathered Mask, Feather Doesn’t Show up
  • Adjustment Layer with Blur and Feathered Mask, Feather Doesn’t Show up
    Posted by Terry Stone on April 23, 2008 at 8:30 pm
    Hi everyone,
    I’m working on a major school project which is due in a few days and i’m stuck on something. I’d appreciate any advice.
    Basically, I have an adjustment layer with the fast blur effect on it. I’ve set up the adjustment layer as a way to blur parts of the background. I also added a mask on the adjustment layer with a feather so that the part of the layer closer to the foreground is sharper. However, even though i’ve added a mask to the adjustment layer, my comp doesn’t show the result of the feather – it’s as if the feather isn’t there at all.
    And advice would be greatly appreciated!
    Francis Battaglia replied 13 years, 4 months ago 3 Members · 2 Replies
  • Roland R. kahlenberg
    April 25, 2008 at 5:09 am
    Adjustment Layers only work with Effects. Masks do not cut through onto its lower layers. That’s if I understand your issues correctly.
    There could also be a possibility that your feather is set to too high a value.
    Having said that, try this –
    Apply your feathered masks on a Solid. Place this Solid as the topmost layer with its Blending Mode set to Stencil ALpha. This may do the trick for you.
    Cheers
    RoRK
    broadcastGEMs.com – the leader in customizable royalty-free animated backdrops
  • Francis Battaglia
    April 18, 2013 at 1:59 am
    You can also pre-compose / pre-comp that top layer with the blur, and then add the mask within the pre-comp.
    Cheers
    Francis
