Activity › Forums › Adobe Premiere Pro › Adjustment layer quick grade scaling with clips beneath – fixable?
  • Adjustment layer quick grade scaling with clips beneath – fixable?
    Posted by Jimmy Brunger on October 9, 2013 at 11:06 am
    Hi all,
    Got to get a quick and dirty grade out really quick today in PPro CC, so doing minor levels corrections on the clips themselves to balance, but then wanted to put an overall look on an adjustment layer above. However every time I get to clip where I’ve animated scale/pos in the edit the adjustment layer seems to move with it but much smaller, meaning I have a floating ‘graded’ square in the middle of my screen, which is not ideal!
    I usually spend more time grading in Ae (and want to properly learn Speedgrade asap, but no time for this job) so thought this would be simple but a bit of a pain!
    Any ideas?
    James
    Adobe CC
    MacPro 3,1 8-core 3.2GHz / 32GB RAM / NVidia Quadro 4000 / OSX 10.8.5
    Decklink Extreme+ 3D / 3TB RAID-0 local / 6TB XServe + United Digital RAID on 10GbE
    Jimmy Brunger replied 12 years, 11 months ago 2 Members · 2 Replies
  • Tim Kolb
    October 9, 2013 at 2:34 pm
    It sounds like you have 1080 media on a 720 timeline?
    The easiest way to get the grade layer to stay ‘stationary’ is to assign the adjustment layer it’s own scaling value…other than 100.
    If you set the adjustment layer to 101…the layer should stay full frame and not follow the underlying clip’s motion properties.
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Jimmy Brunger
    October 10, 2013 at 8:59 am
    It was indeed 1080 footage in 720 timeline…lots of cropping and reframing to do!
    That 101% trick worked perfectly, thanks!
    Adobe CC
