Activity Forums Apple Final Cut Pro adjustment layer LUT bypass
  • adjustment layer LUT bypass
    Posted by Von Jackson on December 11, 2017 at 7:46 am
    Hey guys. I’m new to the forum. I’m using FCPX 10.3. I have an adjustment layer with a LUT over all my clips but everytime I go to tweak the colors/exposure on my clips the adjustment layer gets selected & tweaked instead. is there a way I can bypass the still visible LUT layer and tweak the clips under without having to manually click each one?
    Jeff Kirkland replied 8 years, 8 months ago 4 Members · 6 Replies
  • Noah Kadner
    December 11, 2017 at 1:37 pm
    Color board is per clip/not global, so you need to select individually.
    Noah
    FCPWORKS – FCPX Workflow
    FCP Exchange – FCPX Workshops
    XinTwo – FCPX Training
  • Jeff Kirkland
    December 12, 2017 at 6:56 am
    pressing ‘C’ should select the clip on the primary storyline that’s under the playhead.
    Jeff Kirkland | Video Producer & Cinematographer
    Hobart, Tasmania | Twitter: @jeffkirkland
  • Noah Kadner
    December 12, 2017 at 8:14 am
    Right which in this case will be the “adjustment” layer, which I personally am not a fan of because it’s not something FCPX itself is aware of.
    Noah
  • Von Jackson
    December 12, 2017 at 6:47 pm
    correct. I’m trying to avoid pressing any keys & auto select the under clips as if the layer didn’t exist. Maybe there will be an option in 10.4
  • Jeremy Garchow
    December 13, 2017 at 3:19 am
    Map a key to “select below”.
    I know you want to not press anything and have FCPX know which layer in the stack you want to adjust, but that’s a tall order.
  • Jeff Kirkland
    December 14, 2017 at 6:45 pm
    10.4 now has roles based clip selection. You can use the arrow keys to select the next/previous clip based on its role wherever it may be in the stack.
