Activity Forums Adobe After Effects Adjustment Layer –> Displacement Map?
  • Adjustment Layer –> Displacement Map?
    Posted by Tyler Ammons on November 21, 2016 at 12:44 am
    Hi! I’m working on a video in which im interested in using displacement maps a lot. I wanted to figure out how I could transform an adjustment layer effect (such as ripple) and apply that to something like a solid layer so that I can then use it for a displacement map… Is there any way to do this? I know it sounds dumb, because I should just be using the effect itself instead of displacement, but I was just curious if this was possible.
    Tyler Ammons replied 9 years, 9 months ago 1 Member · 2 Replies
  • Tyler Ammons
    November 21, 2016 at 12:49 am
    Hi! Thanks for the quick answer! Im a little confused though… do you mean duplicate the adjustment layer with the effect? So I have two ripple adjustment layers, then precomp them?
  • Tyler Ammons
    November 21, 2016 at 4:28 am
    Ahhhh…. thanks for the clarification! Very helpful. Ill use that 😉
