Activity Forums Apple Final Cut Pro Adjustment layer changes gamma?
  • Adjustment layer changes gamma?
    Posted by Chris Stevens on January 14, 2016 at 11:01 am
    Applying an adjustment layer with a letterbox crop added & it changes the gamma of all the underlying shots?
    Any ideas why please?
    Chris Stevens – Waterline Media. Marine Production Company.
    FCPX,Motion,AE, Resolve
    Noah Kadner replied 10 years, 8 months ago 3 Members · 9 Replies
  • 9 Replies
  • Noah Kadner
    January 15, 2016 at 3:46 am
    What format is the footage? It might be getting rendered to a different color space than it was shot in originally. You’re only seeing that on the letterbox because its forcing a render vs. just playing back from the original format.
    Noah
    FCPWORKS – FCPX Workflow
    FCP eXchange – FCPX Workshops
  • Chris Stevens
    January 15, 2016 at 9:12 am
    Thanks for the reply Noah.
    The format is XAVC HD @ 100Mb/s (from a Sony FS7). I also have GoPro H264 clips in the edit which behave the same as the XAVC.
    Have tried disabling the adjustment layer then applying an effect, to force a render, this does not create a shift in gamma though?
  • Chris Stevens
    January 15, 2016 at 9:14 am
    Sorry. Correction to my last post.
    The GoPro H264 clips behave in the same way as the XAVC. i.e. the adjustment layer forces a gamma shift.
  • Noah Kadner
    January 15, 2016 at 6:01 pm
    A gamma shift where- in FCPX? Or in the finished footage playing out to a broadcast monitor?
    Noah
  • Chris Stevens
    January 16, 2016 at 11:42 am
    Gamma shift appears in FCPX UI, on monitor via Black magic Ultra I/O & on exported ProRes file.
  • Jeff Kirkland
    January 16, 2016 at 11:58 am
    What are you using as an adjustment layer? Have you tried a different adjustment layer? What effects are applied to it? What happens if you apply the adjustment layer over footage in a new project?
    Just wondering if it’s the adjustment layer, or something applied to it that’s causing the colour shift.
    Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
    http://www.southerncreative.com.au | G+: https://gplus.to/jeffkirkland | Twitter: @jeffkirkland
  • Chris Stevens
    January 16, 2016 at 12:28 pm
    Using the adjustment layer from the text browser. Didn’t know there was an alternative? Please advise.
    Applying a letterbox crop.
    Same gamma shift when in new project.
  • Chris Stevens
    January 19, 2016 at 8:43 am
    Have solved the issue.
    Opened the adjustment layer, from the text browser, into motion. Changed nothing then published it to FCPX.
    All ok now. No idea why?
  • Noah Kadner
    January 19, 2016 at 10:42 pm
    Might have had something hidden someplace that caused that shift- hard to say. In general I find copy/paste attributes a lot more predictable/useful than adjustment layers which are really more of a workaround in FCPX and not so much a built-in workflow.
    Noah
