Adjustment layer bug in CC 2018
I’m applying an adjustment layer with three effects, Simple Choker, Roughen Edges and Turbulent Displace at the top of the stack, above a bunch of shape layers. Only the one at the bottom is being affected, the remaining three, are left untouched. If I sort the layer order, whatever layer ends up in the bottom gets the effects applied, but the others don’t.
I think is this a bug, unless anyone can tell me otherwise?
