Activity Forums Avid Media Composer Adjusting Volume on several segments at once.
  • Adjusting Volume on several segments at once.
    Posted by Trevor Ambrose on June 30, 2021 at 6:34 pm
    Hi Folks,
    Is there a way to adjust volume on several segments at once (while still keeping their db relationships. i.e. segment A is at +3db , segment B is at -1db and segment C is at 0db THEN I want to raise them up all by +3db. So they end up at: A +6db, B +2db and C +3db.
    I know I can do this on FCP using “Control [” but I’m not sure if Avid can do this.
    Any ideas would be appreciated.
    Trevor Ambrose
    editor – SCHITT’S CREEK
    https://www.imdb.com/name/nm0024430/
    Matt Lyon replied 5 years, 2 months ago 2 Members · 3 Replies
  • Matt Lyon
    July 1, 2021 at 4:13 pm
    Hey Trevor, you can do this using the “adjust pan/vol on tracks – in/out” command in the hamburger menu on the top right of the audio mixer tool. You can map the command to a keyboard shortcut, although I believe in older versions of Media Composer this wasn’t possible. If you don’t have an in/out set in the timeline, I believe the change will affect the entire selected track(s).
    Hope this helps,
    Matt
    http://www.mattlyon.info
  • Trevor Ambrose
    July 1, 2021 at 4:54 pm
    Hey! A fellow Canadian!
    Thanks Matt. This is really helpful. Changing global volumes while keeping there db relationship is so helpful.
    Have a good weekend!?
  • Matt Lyon
    July 1, 2021 at 6:38 pm
    Fellow CCE member too 🙂 I bet we have lots of mutual acquaintances. Have a great weekend too!
