Activity › Forums › VEGAS Pro › Adjusting volume on part of track
  • Adjusting volume on part of track
    Posted by Nshon7 on November 13, 2005 at 1:41 pm
    Hi there, newbie user so please bear with me.
    I’ve inserted a mp3 track and want to reduce volume of this track where I want some speeches to be heard. I only seem to be able to adjust the volume of the entire track and not certain sections. How do I do it? TIA.
    Regards,
    Nash
    Gary Kleiner replied 20 years, 10 months ago 4 Members · 4 Replies
  • Don Bloom
    November 13, 2005 at 10:17 pm
    insert a volume envelope in the track and place 4 nodes (points) where you need to lower the volume pul the level to where you need it(generally around -12db but its up to you)and you’re set to go.
    Don B
  • Gary Kleiner
    November 13, 2005 at 11:07 pm
    To expands on Don’s post:
    Insert an envelop by selecting the track header and hitting the v key. Place the nodes by double-clicking on the blue line that appears.
    Gary
  • Ted Snow
    November 14, 2005 at 6:49 am
    When placing the 4 nodes…place two of them close together at the beginning of the sequence and two nodes close together at the end…then pull down the center part. This will create a “dip” in the volume.
  • Gary Kleiner
    November 14, 2005 at 3:42 pm
    [Ted Snow] “When placing the 4 nodes…place two of them close together at the beginning of the sequence and two nodes close together at the end”
    .. or you can do this with one click with Excalibur’s 4-Points tool 🙂
    Gary
