Activity Forums Apple Final Cut Pro Legacy Adjusting video levels via Video scopes before capturing
  • Adjusting video levels via Video scopes before capturing
    Posted by Dan Skinner on July 12, 2006 at 10:25 pm
    Is it possible to adjust the controls of the Video Scopes in the log Capture window? I am not set up to bars on the tape in final cut. The sliders to do so are grayed out. any ideas?
    Walter Biscardi replied 20 years, 2 months ago 5 Members · 5 Replies
  • Debe
    July 12, 2006 at 10:57 pm
    If you are capturing via firewire, you are actually ingesting a data stream, so there are no video or audio levels to speak of. You’ll need to do your adjustments after the fact, or capture through an I/O card that allows for level adjustments.
    debe
  • Bouncing Account needs new email address
    July 12, 2006 at 10:58 pm
    You can’t do this if you are capturing via FireWire.
    If you have certain brands of analog capture cards, they have the software for making the input controls operate in FCP.
    Otherwise, you either need an outboard ProcAmp (or TBC) or just make your adjustment IN the FCP edit.
    July 12, 2006 at 10:59 pm
    There must be an Echo Echo Echo Echo Echo in here 😉
  • Chris Poisson
    July 13, 2006 at 2:49 pm
    Echo, echo, echo!!! Don’t know about other cards but my Kona LH has controls for setup and a procamp built in. Plus I have control over audio levels.
    Have a wonderful day.
  • Walter Biscardi
    July 13, 2006 at 2:51 pm
    [Chris Poisson] “Don’t know about other cards but my Kona LH has controls for setup and a procamp built in. Plus I have control over audio levels.”
    With Analog sources. But with SDI, you need to make the adjustments after you bring the footage in or you need to adjust at the Deck during Capture.
    Walter Biscardi, Jr.
