Activity › Forums › AJA Video Systems › Adjusting Video Input sign
Posted by Mark Griesbauer on August 15, 2007 at 1:34 pmHi and sorry for the easy question…but how do you adjust the Hue and saturation w/the AJA IO LA? The sliders the these controls are greyed out in FC so I’m guessing I have to adjust with the AJA IO LA? any help will be much appreciate and thnx in advance
markChris Tompkins replied 19 years, 1 month ago 3 Members · 5 Replies -
Lee Berger
August 15, 2007 at 2:00 pmYou should have the AJA “Control Panel” Application installed (look in your Utilities folder). If not you can download it from AJA support. It has several preset slots to save your settings. Unfortunately with the IO product line you cannot run the control panel and FCP at the same time so you won’t have access the scopes in FCP. I use hardware scopes. Perhaps someone knows of a third party software scope for OS X.
Mark Griesbauer
August 15, 2007 at 5:09 pmHey thnx so much for such a quick reply…I guess I better button my lip and just accept that I piece of hardware might not be all friend w/FCP. So the scope in FCP is no good to me? I mostly digitize from Beta SP and we do have a scope here…however it is in another edit suit across the hall and I would have to try to be in 2 places @ once…oh well…thnx again.
Mark Griesbauer
August 15, 2007 at 5:54 pmOh…another…why is there NO communication with my beta dck after I use the control panel?
Lee Berger
August 17, 2007 at 9:23 amI don’t know why you lost deck control. Try turning IO off and on. On the levels issues thing you might consider is borrowing the scope to set your input levels correctly for color bars. You could then save the settings as a preset in the control panel. After capture you can use the scope and filters inside FCP to adjust video levels. I like the 3-Way Color correction filter for this purpose. Best of luck.
Lee Berger
http://www.leebergermedia.com -
Chris Tompkins
August 24, 2007 at 6:38 pmBe sure to always click on the desktop when switching between the IO Control panel and FCP. This will save on the issues somewhat
