Activity Forums Adobe Premiere Pro Adjusting Timecode outside of Premiere Pro?
  • Adjusting Timecode outside of Premiere Pro?
    Posted by Dirk Dejonghe on July 2, 2012 at 10:05 am
    Is there a way to change metadata timecode with reference to a particular frame using a simple program (not Final Cut or Premiere or similar).
    I want to position the cursor on a particular frame of the H264 clip and then give a timecode valid for the entire clip. Easy enough in Premiere but I need something free or cheap. PAL SD formats only.
    Dirk Dejonghe replied 14 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
