Activity Forums Adobe Premiere Pro Adjusting the split view bar in the 3-way color corrector
  • Adjusting the split view bar in the 3-way color corrector
    Posted by Steve Goldberg on January 25, 2014 at 12:02 am
    Hi, I’m trying to figure out how to see my before and after color correction using the split view and I only see how to do it with the split directly down the center. I don’t see a way to drag the line of the split view, like I can in FCP7.
    I thought that maybe if I highlighted the 3-way CC in the effects controls, a grabber line would appear in the program window, but this did not happen. Does the split view only allow for a non-moveable bar? What if that spot in the frame is not a good spot to evaluate the difference?
    Thanks for any help on this,
    SteveG
    Ann Bens replied 12 years, 8 months ago 2 Members · 1 Reply
  • Ann Bens
    January 25, 2014 at 8:29 pm
    Twirl down Split View, there you will find several parameters to adjust.
    Adobe Certified Expert Premiere Pro CC
    Adobe Community Professional
