Activity Forums Adobe After Effects Adjusting the sound volume multiple times
  • Adjusting the sound volume multiple times
    Posted by André Kama on August 29, 2017 at 10:38 pm
    I’m a beginner in After Effects and I’m having issues with one of my first videos. I’d like to know how to change a parameter more than once without having a transition between each of these changes. This probably doesn’t make any sense, so let me explain what I’m trying to do :
    – I have a background music at a normal sound level (0dB).
    – After some time, I would like this music to be at a lower level. I’ve been able to do it using the method described here : https://youtu.be/wvCgFygKt_A?t=1m39s
    – Now I want the sound volume to get back to its original level after some time, and using this same method, it would just get higher gradually.
    How can I achieve this? I’d be happy to go into more details if it’s hard to understand.
    André Kama replied 8 years, 12 months ago 2 Members · 2 Replies
  • Logan Smith
    August 30, 2017 at 1:40 pm
    Hi André
    You just need to add a new keyframe
    Here is a basic keyframe tutorial for After Effects
    https://www.youtube.com/watch?v=LSoj-6JSv-c
  • André Kama
    August 31, 2017 at 4:37 pm
    Yes, I figured out how to do it soon after posting this thread. However, I’m considering using the solution mentioned in the first answer for my next projects. When you are using different videos shot by different people, it may be hard to keep the volume consistent.
