Activity › Forums › Zaxwerks › Adjusting the Postion of Object in 3D Space
  • Adjusting the Postion of Object in 3D Space
    Posted by Corey Holtgard on April 17, 2012 at 8:59 pm
    I am trying to position a 3D logo made with Pro Animator in a AE sequence that is linked to the comp camera, I have it all linked up to the comp camera, but now the logo is WAY to close. If I move the position for my camera to make the logo smaller it throws the tracking off (I have tracked the camera to the footage using The Foundry CameraTracker)
    So I am wandering how to move the position of the logo in 3D space without messing with the camera position….. Am I looking at this the wrong way or just missing a simple control feature?
    Producer | JBO Production | addictedtotheoutdoors.com
    Edward Wu replied 14 years, 3 months ago 2 Members · 3 Replies
  • Edward Wu
    April 18, 2012 at 7:55 pm
    Hi Corey,
    Go into the ProAnimator Set-Up window, and go to the Object Controls Panel. Expand the controls for the “Info” section and you will be able to see the position of the object. Adjust the position of the object until it is the position that you need, and it should work for you.
    Best,
    Edward
  • Corey Holtgard
    June 28, 2012 at 6:06 pm
    Thanks for this! Helped out and I was able to get it working
    Head of Production – Outhouse Entertainment – outhousetv.com
  • Edward Wu
    June 28, 2012 at 6:51 pm
    No problem at all. Thanks for the update and I’m glad to hear that everything is working for you now.
    Best,
    Edward
