Activity Forums Boris FX Adjusting Reflection Track to properly simulate glass
  • Adjusting Reflection Track to properly simulate glass
    Posted by Steve Pankow on April 12, 2005 at 12:05 am
    Say you have a spline object with a Glass material over V1. If you turn on the reflection track and also set it to V1, the reflection is rather distorted, and there’s no adjustments for scale and whatnot. You can copy a V1 track into a container and place that into the reflection track, but if you move the spline obeject the reflection doesn’t track with it.
    What I’m looking for is something akin to the various “crystal” effects that NBC uses, where a crystalline version of the peacock logo passes over a piece of video and the reflected image either distorts or is slightly larger inside of the spline object – is there an easy way to replicate this?
    Steve Pankow replied 21 years, 4 months ago 1 Member · 1 Reply
  • Steve Pankow
    April 12, 2005 at 4:25 pm
    Hate to reply to my own post but I was thinking perhaps I should duplicate the base video layer, blow it up a bit and then use a duplicate of the spline object as a mask on it. Then as the “crystal” object tracks across the screen, the mask would only show the enlarged duplicate of the track directly underneath/through it. Anyone agree or disagree?
