Activity Forums Apple Final Cut Pro Legacy Adjusting Motion Effects to Multiple Clips in a Bin
  • Adjusting Motion Effects to Multiple Clips in a Bin
    Posted by Chris Holland on March 9, 2011 at 3:31 pm
    Hi all,
    Hope all is well. First off to set the scene we shoot on a Panasonic HVX-200 with a 35mm adaptor and it flips the footage. I tend to go through my footage in the bins before adding it to a timeline.
    What I have been doing is going into the motion settings and rotating the clips by 180. The problem is that when there are a lot of clips I can’t figure out a way to do it to multiple clips or to just copy the attributes. Trying to use copy then Paste Attributes doesn’t work. Is there a way to copy motion settings to other clips in a bin or to do a mass motion change in a bin ?
    I realize i can drop all the clips into a timeline and then copy the attributes to every other clip but I was just hoping there was a way to do it in the bins to the Raw Shots.
    Thanks.
    Chris
    Chris Holland
    Editor/Animation/Design
    hollandedit.com
    Dan Monro replied 15 years, 5 months ago 2 Members · 1 Reply
  • Dan Monro
    March 10, 2011 at 7:04 pm
    How about saving your 180 flip as a motion favorite? I don’t know of a way to apply it to a group of clips at the bin level, but at least its a simple keystroke (control shift 5) once you call up a clip. If you do it prior to cutting, just apply the favorite each time you put a clip in the viewer.
    Not a solution, but a workaround…
    Cheers,
    D
    Dan Monro
    FCP, Avid, AfterFX, Atlanta
    MacBook Pro 2.53 GHz Intel Core i5 4 GB ram
    Mac OS X 10.6.4
    NVIDIA GeForce GT 330M
    Final Cut Pro 7 Quicktime 7.6.6
    – OR –
    2 x 3.2 Quad Xeon; 16 GB ram
    Mac OS X 10.6.4
    NVIDIA Quadro FX 5600 Final Cut Pro 7.0.2 Quicktime 7.6.6
