Activity Forums DaVinci Resolve Adjusting mask softness without effecting key-frames.
  • Adjusting mask softness without effecting key-frames.
    Posted by Steve Davies on August 31, 2012 at 9:57 am
    Hi, I’m still stuck on this problem and can find no help in the manual.
    Just to reiterate:
    I have an animated window and I want to adjust the window feathering. The problem is that any changes to the edge softness is recorded in the current key-frame and doesn’t change the window globally. So I can’t adjust the window softness after tracking it without having to start from scratch.
    Thanks.
    Brandon Thomas replied 13 years, 8 months ago 2 Members · 1 Reply
  • Brandon Thomas
    September 1, 2012 at 12:31 am
    Steve, I think you’re sort of out of luck.
    If it’s a curve, you’re even more out of luck.
    The only real option I’m aware of is to go to each keyframe and make the adjustment on a keyframe by keyframe basis. If it’s a circlular window, you can easily copy and paste. other than that, it’s quite a bit more tedious.
    No promises on this, but maybe try duplicating the node in question (by copy and pasting it into another node) feeding that as a matte into the current node, inverting it, and then adjusting the settings in the key tab. It’s worth a shot.
